Power over ethernet adapters
Nerfherder
I'm doing a CCTV DIY project and home and the cameras im using have ethernet ports and use a 5v power adapter.
I want to run a single cable to each camera, so will need the full splitter kit.... unless I just get a small POE switch and then I just need the POE splitter on the camera side.
I looked at Scoop and could not see the 5v adapter, there is 12 and 24 but not 5v. I did google and I can see it exists but does anyone know of a local distributor ?
I basically need the 5v version of this:
http://www.scoopdistribution.co.za/product_info.php/passive-poe-injector-and-splitter-set-p-1601
