Prometheus
Banned
- Mar 19, 2006
Depends on what your setup is.
Prometheus said:Depends on what your setup is.
Umm... cryptic description. I'll take a try.JasTin said:Well everything is insulated *damn this iBurst is actually fast *gasp**
anyway......erm network point from PC along with power from adapter *using brown and white/blue cables*running to power input and point on UTD, antenna cable from UTD to antenna outside on DSTV dish mast pointing towards plumbstead I guess...
Sorry for bad description....
Prometheus said:Umm... cryptic description. I'll take a try.
"Network point from PC along with power from adapter" (network cable from pc + power cable) "running to power input and point on UTD" (ok as long as they are kept separate), "antenna cable from UTD to antenna outside on DSTV dish mast pointing towards plumbstead I guess..." (I hope that dish mast is earthed, otherwise first lightning strike it's bye-bye DSTV and pc+UTD)
Everything else seems good as long as it's insulated.
I would still recommend getting a surge protector with an antennae throughput to be safe. Make sure it has an indicator light telling you that it's still working.JasTin said:yep that pretty much it!
erm I guess the mast it earthed......it bolted to the wall.........![]()
Prometheus said:I would still recommend getting a surge protector with an antennae throughput to be safe. Make sure it has an indicator light telling you that it's still working.
Look for one of these:JasTin said:Cool thanks boet I will
P.S. I must say, damn iBurst is actually fast!.....who woulda thought!
Ekhaatvensters said:It is pretty nice hey.. I thaught you wouldnt be gretting such a great service with just a UTU in the roof.
But damn.. your pings are better than mine now, and you speeds.
Should never have put the idea in your head..
