PPPOE client disconnect issues
thaabiet
Hello all,
My setup
Modem(bridge mode) --> Mikrotik RB 750 ---> Ubiquiti Rocket M5 (Bridge mode) -----> pppoe clients (bridge mode )
The mikrotik is configure as a pppoe server, and I have no problem connecting to the pppoe server and gaining access to the network. However at random times and I do experience pppoe clients disconnecting :twisted:, it happens often and with some not at all. Please assist :confused:
P.s openweb :love: rules
Make sure you have the latest firmware (5.3.3) installed on the Rocket and clients. Set the Rocket to AP-WDS mode. Set the clients to Station-WDS mode.
Thank you for your reply, the access point is correctly set to best p-t-mp configuration, including wds settings and the latest firmware, signal quality on all clients are more that fantastic.
What RouterOS version have you got on the RB750? If you upgraded from v4.x to v5.x without doing a clean config that could also be causing the problem. Try loading latest RouterOS, remember to also do the "system routerboard upgrade" command after loading new RouterOS to upgrade the routerboard firmware. After upgrading the firmware reset to system defaults and do a clean reconfig. Hope that helps...
I'm having same issue as you.Your config is fine,it's actually a problem between the mikrotik and rocket device,seems to be some sort of buffer overflow issue and trying to resolve it with Ubiquiti.If they manage to help me i'll post a reply with an answer.
disable pppoe encryption on your mikrotik router under pppoe server profiles.
Thread Necro :)
My MikroTik recently started disconnecting PPPoE connections as well.
I haven't used the WiFi on it for ages, but use it to split data between capped and a slow uncapped connection.
Under: PPP -> Profiles -> Default
Turning off the encryption seems to have stopped the disconnects which have been growing more and more frequent.
Thanks!
Enable de-bug mode on the RB and paste the reason for the disconnects
Code:
20:39:40 pppoe,ppp,debug,packet  ploc: sent LCP EchoReq id=0x18
20:39:40 pppoe,ppp,debug,packet     <magic 0x12bac2f>
20:39:40 pppoe,ppp,debug,packet  ploc: rcvd LCP EchoRep id=0x18
20:39:40 pppoe,ppp,debug,packet     <magic 0x47a483db>
20:39:41 pppoe,ppp,debug,packet  ploc: rcvd LCP EchoReq id=0x2f
20:39:41 pppoe,ppp,debug,packet     <magic 0x47a483db>
20:39:41 pppoe,ppp,debug,packet      2f ac 2b 01
20:39:41 pppoe,ppp,debug,packet  ploc: sent LCP EchoRep id=0x2f
20:39:41 pppoe,ppp,debug,packet     <magic 0x12bac2f>
20:39:41 pppoe,ppp,debug,packet  pint: rcvd LCP EchoReq id=0x2f
20:39:41 pppoe,ppp,debug,packet     <magic 0x5ca483db>
20:39:41 pppoe,ppp,debug,packet      d9 d6 ff 1d
20:39:41 pppoe,ppp,debug,packet  pint: sent LCP EchoRep id=0x2f
20:39:41 pppoe,ppp,debug,packet     <magic 0x1dffd6d9>
20:40:22 pppoe,debug poe: terminating sessions: interface state changed
20:40:22 pppoe,ppp,debug ploc: LCP lowerdown
20:40:22 pppoe,ppp,debug ploc: LCP closed
20:40:22 pppoe,ppp,debug ploc: CCP lowerdown
20:40:22 pppoe,ppp,debug ploc: BCP lowerdown
20:40:22 pppoe,ppp,debug ploc: BCP down event in starting state
20:40:22 pppoe,ppp,debug ploc: IPCP lowerdown
20:40:22 pppoe,ppp,debug ploc: IPCP closed
20:40:22 pppoe,ppp,info ploc: terminating... - disconnected
20:40:22 pppoe,ppp,debug ploc: LCP down event in starting state
20:40:22 pppoe,ppp,info ploc: disconnected
20:40:22 pppoe,ppp,debug pint: LCP lowerdown
20:40:22 pppoe,ppp,debug pint: LCP closed
20:40:22 pppoe,ppp,debug pint: CCP lowerdown
20:40:22 pppoe,ppp,debug pint: BCP lowerdown
20:40:22 pppoe,ppp,debug pint: BCP down event in starting state
20:40:22 pppoe,ppp,debug pint: IPCP lowerdown
20:40:22 pppoe,ppp,debug pint: IPCP closed
20:40:22 pppoe,ppp,info pint: terminating... - disconnected
20:40:22 pppoe,ppp,debug pint: LCP down event in starting state
20:40:22 pppoe,ppp,info pint: disconnected
20:40:23 pppoe,ppp,info ploc: initializing...
20:40:23 pppoe,ppp,info ploc: dialing...
20:40:23 pppoe,ppp,info pint: initializing...
20:40:23 pppoe,ppp,info pint: dialing...
20:40:24 pppoe,debug,packet poe: sent PADI to FF:FF:FF:FF:FF:FF
20:40:24 pppoe,debug,packet     session-id=0x0000
20:40:24 pppoe,debug,packet     host-uniq=0x109b
20:40:24 pppoe,debug,packet     service-name=
20:40:24 pppoe,debug,packet     host-uniq=0x109c
20:40:25 pppoe,debug,packet poe: sent PADI to FF:FF:FF:FF:FF:FF
20:40:25 pppoe,debug,packet     session-id=0x0000
20:40:25 pppoe,debug,packet     host-uniq=0x109b
20:40:25 pppoe,debug,packet     service-name=
20:40:25 pppoe,debug,packet     host-uniq=0x109c
20:40:26 pppoe,ppp,info ploc: terminating... - disconnected
20:40:26 pppoe,ppp,debug ploc: LCP lowerdown
20:40:26 pppoe,ppp,debug ploc: LCP down event in starting state
20:40:26 pppoe,ppp,info ploc: disconnected
20:40:26 pppoe,ppp,info pint: terminating... - disconnected
20:40:26 pppoe,ppp,debug pint: LCP lowerdown
20:40:26 pppoe,ppp,debug pint: LCP down event in starting state
20:40:26 pppoe,ppp,info pint: disconnected
20:40:26 pppoe,ppp,info ploc: initializing...
20:40:26 pppoe,ppp,info ploc: dialing...
20:40:26 pppoe,debug,packet poe: sent PADI to FF:FF:FF:FF:FF:FF
20:40:26 pppoe,debug,packet     session-id=0x0000
20:40:26 pppoe,debug,packet     host-uniq=0x109d
20:40:26 pppoe,debug,packet     service-name=
20:40:26 pppoe,debug,packet poe: rcvd PADO from 00:14:A8:56:4B:3C
20:40:26 pppoe,debug,packet     ac-name=rnls-ip-esr-2
20:40:26 pppoe,debug,packet     ac-cookie=70 c9 9a 05 7d 4d 2d 82 3d ae 22 35 17
 bb c0 7f
20:40:26 pppoe,debug,packet poe: sent PADR to 00:14:A8:56:4B:3C
20:40:26 pppoe,debug,packet     host-uniq=0x109e
 bb c0 7f
20:40:26 pppoe,debug,packet poe: rcvd PADS from 00:14:A8:56:4B:3C
20:40:26 pppoe,debug,packet     session-id=0xaa03
 bb c0 7f
20:40:26 pppoe,ppp,debug ploc: LCP lowerup
20:40:26 pppoe,ppp,debug ploc: LCP open
20:40:26 pppoe,ppp,info pint: initializing...
20:40:26 pppoe,ppp,info pint: dialing...
20:40:26 pppoe,debug,packet     host-uniq=0x109f
 bb c0 7f
20:40:26 pppoe,debug,packet     host-uniq=0x10a0
 bb c0 7f
20:40:26 pppoe,ppp,debug ploc: LCP timer
20:40:26 pppoe,ppp,debug,packet  ploc: sent LCP ConfReq id=0x78
20:40:26 pppoe,ppp,debug,packet    <mru 1480>
20:40:26 pppoe,ppp,debug,packet    <magic 0x53db53c6>
20:40:26 pppoe,ppp,debug,packet  ploc: rcvd LCP ConfNak id=0x78
20:40:26 pppoe,ppp,debug,packet    <mru 1492>
20:40:26 pppoe,ppp,debug,packet  ploc: sent LCP ConfReq id=0x79
20:40:26 pppoe,debug,packet     session-id=0xab03
 bb c0 7f
20:40:26 pppoe,ppp,debug pint: LCP lowerup
20:40:26 pppoe,ppp,debug pint: LCP open
20:40:26 pppoe,ppp,debug,packet  ploc: rcvd LCP ConfAck id=0x79
20:40:27 pppoe,ppp,debug pint: LCP timer
20:40:27 pppoe,ppp,debug,packet  pint: sent LCP ConfReq id=0x7e
20:40:27 pppoe,ppp,debug,packet    <mru 1480>
20:40:27 pppoe,ppp,debug,packet    <magic 0x73d90efd>
20:40:27 pppoe,ppp,debug,packet  pint: rcvd LCP ConfNak id=0x7e
20:40:27 pppoe,ppp,debug,packet    <mru 1492>
20:40:27 pppoe,ppp,debug,packet  pint: sent LCP ConfReq id=0x7f
20:40:27 pppoe,ppp,debug,packet  pint: rcvd LCP ConfAck id=0x7f
20:40:28 pppoe,ppp,debug pint: LCP timer
20:40:28 pppoe,ppp,debug,packet  pint: sent LCP ConfReq id=0x80
20:40:28 pppoe,ppp,debug,packet    <mru 1492>
20:40:28 pppoe,ppp,debug,packet    <magic 0x73d90efd>
20:40:28 pppoe,ppp,debug,packet  pint: rcvd LCP ConfAck id=0x80
20:40:28 pppoe,ppp,debug ploc: LCP timer
20:40:28 pppoe,ppp,debug,packet  ploc: sent LCP ConfReq id=0x7a
20:40:28 pppoe,ppp,debug,packet    <magic 0x53db53c6>
20:40:28 pppoe,ppp,debug,packet  ploc: rcvd LCP ConfAck id=0x7a
20:40:28 pppoe,ppp,debug,packet  ploc: rcvd LCP ConfReq id=0x2
20:40:28 pppoe,ppp,debug,packet    <magic 0xb2a2b3db>
20:40:28 pppoe,ppp,debug,packet    <auth pap>
20:40:28 pppoe,ppp,debug,packet  ploc: sent LCP ConfAck id=0x2
20:40:28 pppoe,ppp,debug ploc: LCP opened
20:40:28 pppoe,ppp,debug,packet  ploc: sent PAP AuthReq id=0x69
20:40:28 pppoe,ppp,debug,packet     <user ****2>
20:40:28 pppoe,ppp,debug,packet     <password ****2>
20:40:28 pppoe,ppp,debug,packet  ploc: rcvd PAP AuthAck id=0x69
20:40:28 pppoe,ppp,info ploc: authenticated
20:40:28 pppoe,ppp,debug ploc: IPCP lowerup
20:40:28 pppoe,ppp,debug,packet  ploc: sent IPCP ConfReq id=0x51
20:40:28 pppoe,ppp,debug,packet     <addr 0.0.0.0>
20:40:28 pppoe,ppp,debug,packet     <ms-dns 0.0.0.0>
20:40:28 pppoe,ppp,debug ploc: IPCP open
20:40:28 pppoe,ppp,debug ploc: BCP open
20:40:28 pppoe,ppp,debug ploc: CCP lowerup
20:40:28 pppoe,ppp,debug ploc: CCP open
Finally took the antenna off the roof... seems like the PoE injector is the issue.
The PoE port was dropping for a fraction of a second, causing its "Interface State" to change.
Connecting the power directly to the board but still using the same cable, the connection is rock solid.
Oh - this might mean the cable between the PoE is faulty as well...
During all my fiddling I messed up something though... Not all https works anymore :(
