Printer settings, Draft quality etc?
ponder
Niflheimr
I have a HP Officejet 6313 All-in-one printer and the HP drivers installed.
I'm trying to set the print quality to Draft like one can do in Windows so you use less ink but nowhere in the System Preferences or HP Utility can I find anything related to this.
Any ideas?
I just found out that once you select print from the application there is a drop down menu to select Fast Draft but the output still looks very black to me, ie. using a lot of ink.
