Problem with bridged mode
3Y3W17N355
Stellenbosch
Whenever i connect to the internet in bridged mode it connects but I cant browse any sites (local or international) and nothing else that uses the internet works either.
It works whenever I connect with my sisters computer, but not on mine.
I've switched my modem/router back to PPPoE and it works perfectly again.
How can I get it to work in bridged mode?
I have a Billion BiPAC 5102 modem/router
When using bridge mode you have to dial out to the isp from your pc, but im assuming you know that already since you sisters pc works. Check whether your firewall is allowing you access to the router. But if your pc is dialling out to the isp successfully then its nothing to do with the router. Either your isp is gone crazy or your firewall is blocking all access.
Bridged mode only works properly if your set your lan IP manually
hmm ok nevermind. I know some routers only work with raspppoe and bridged mode if you set the ips manually
