Hi,
I know this has been posted to death! I know because I have spent the past 7 or so hours searching for a solution.
My problem in a nutshell is that I am unable to get my new Linksys WRT54G3G router to work with my Huawei E620 datacard.
I have upgraded the firmware of the router to the latest I could find i.e. (2.11.05). My problem is that as soon as I insert the Datacard into the router, the router seems to hang. If I try to access the admin page via the browser, I cannot, if I release my IP address and refresh, I get nothing and even the wireless stops working. Unplug the datacard and after about 3 seconds, everything starts to function. I have switched the router off, plugged the datacard in and then get the same problem, this time the power LED does not stop flashing as it is suppose to.
I have now gone as far as trying my datacard in another identical linksys router to eliminatye the posibility that the router is faulty.
The datacard works 100% in both my wifes and my own laptop. I have a "strong" feeling the problem is the to do with the firmware on my datacard. My datacard has firmware 11.16.09.06.X and I have read the router needs 11.16.09.09.11. I have managed to download the new firmware for my datacard (This was after hours of searching) and have a problem when installing it. It comes up and tells me : Software is not compatible, access is forbidden. I am not sure if this is to do with the locking on the datacard? I have tried to unlock the datacard but with no success.
I have phoned Vodacoms help line and the technician was not able to assist.
Judging from past posts, there seems there is a problem with the e620 cards and the linksys router but there are also many cases where guys go it working by upgrading the router firmware. This has not helped me. My datacard is pretty old, at least 2 and half years which would explain the old firmware.
I would really appreciate any ideas or solution that you may have!!!
Regards
Mike
Regards
Mike
