Philip Foglar
- Mar 27, 2008
Hi guys,
And first post, so hello all.
I have been having major hassles for the last month now to interact with a few forums that are specifically using Invision Power Boards software. System is correctly set-up and there are two PCs on the ADSL connection running IE, Firefox and on my main system even running Ubuntu with Firefox. All browsers in the various combinations give exactly the same results. That is, I will enter the forum and be asked to login which never used to be the case in the past since I always have it remember to login. The forums themselves which are not local and are visited throughout the day internationally is working fine considering how many people are posting and so on. At my work these forums seem to allow me to stay logged in though once initially logging in at the start of the session - again, never required this once "remember" is ticked.
To give background, I was using ABSA ADSL up until Atlantic took it over mid February and turned service into no-service. But while I was with ABSA and just before the no-service effect took place I was having no problems whatsoever with these forums. I then moved over to Axxess and went for their ADSL 3GB shaped account which I am perfectly happy with, just not the forum issue. I have reported this to them and in turn they have queried with SAIX - no fault on their side so they say, and must be a fault with these boards... Right...
Any ideas what could be the cause of this? I think it is fair to say that the fault is not with the boards or with my connection since everything else works and browsing other forums (locally and international) which use different software seems to be working perfectly, can only be something local. I am also pretty sure that it is an IP address issue since your user account is linked to your IP address. But as in the past, I never had any problems when interacting with these forums from both home or at work and never had to login unless of course I cleared the browser. Anyone else experiencing this problem?
Kind regards,
Philip.
Kind regards,
Philip.
