Problems with Duo Plus WR300 ADSL Router
bradlesliect
Hi,
Has anyone experienced the problem below with this router
1. All of a sudden the wifi connection becomes extremely slow - the signal is excellent but it almost grinds to a halt when browsing network and/or internet.
What is the radius / network range for this router i.e. how far before the wifi drops? Are there any other probs I need to be aware of with this device?
I had a read through the documentation. Nothing much in it to give specifications in terms of throughput or range.
I have seen some people reporting poor wireless connectivity.
Google also shows a lot of people trying to sell the modem so maybe the performance you are experiencing is a common one.
If you connect with a cable what is the response like?
If it is good with cable then the wireless on the router or the PC is the issue.
Regards
Tim
On cable or wifi the problem is the same. I use my notebook(win 7) on the wifi and the minute it appears that I am reaching a point that could be out of range, the network setting changes to "public network" and everything goes for a ball of twit.
