Programme to copy movies between 2 portable HDDs
marco79
Back in CPT!
Could anyone recommend a good programme to use to copy movies from 1 portable hard drive to another? It's both Samsung HDDs. Or should I just use the standard Windows copy and paste.
Sent from my Desire HD using MyBroadband Android App
Teracopy because its a +1 and you can queue files so it moves at a constant speed.
I will try teracopy. Thanks.
Or this free one:
Code:
@echo off
cls
@echo Copy MOVIES from USB Drive J to USB Drive K
@echo.
@echo.
pause
xcopy J:\Movies\*.* K:\Movies\*.* /D /E /H /Y /Z /J
pause
Make appropriate changes for your drives and folders, then save in a TXT file and rename is to CMC.cmd (for "Copy My Movies", or whatever you prefer) and execute.
Or this free one:
Code:
@echo off
cls
@echo.
@echo.
pause
pause
Rather use TeraCopy, it can confirm, shutdown the PC, stay open, close and a lot more.
Geez you guys have become lazy :D
You can easily shut down by using a shutdown /f /<insert other switch here> command at the end of the batch file.
