Hey everyone,
This is my first post on MyBroadband (I have been a reader here for a while though), so "Hello" to the community
Looking forward to being a active/helpful member of this board.
I want to build a machine which can play games at decent framerates and generally give a good value for money. I am going to spend about R8000-R9000 on the machine so no i7 and 4870x2/GTX295's for me.
So far this is what I have put together after weeding through alot of personal and professional opinions online:
Motherboard: Jetway XBlue-G45.
Jetway may sound foreign but its not all that bad. Plus a motherboard with G45 chipset for just under R1000 isn't all that bad. The bios also allows to easily alter the voltage/multiplier/etc for some good overclocking.
CPU: Intel Core2Duo E8400 3.0Ghz
E8400 has the exact same features as its more powerful variants E8500/E8600. From what I have gathered, E8400 can reach E8600 speeds (3.33Ghz) with a stock Fan and Heatsink. The price difference between E8400 and E8500/E8600 is quite significant so I wanna stick to E8400.
Ram: 2 x 2GB Kingston DDR2-800Mhz
Nothing really to say here. 4GB of RAM should be enough for most multi-tasking/gaming needs.
Graphics Card: Point Of View Nvidia 9800GTX+ 512MB
The card falls in the R2500-R2800 range and performance wise its between mid-range (9800GT) and high-end (9800GX2). It should play most games at decent framerates on a 19" monitor.
Hard-Drive: Seagate 1TB Sata, 32MB cache
I've checked with the supplier. This is a newer seagate drive and does not suffer from the lockup problem recently ranted about all over the net.
So far the above setup is already touching R7500. I still need a new case and a power supply to run the whole show.
I am concerned about the power supply as any decent PSU above 450/460Watts rips through R1000 mark. Will i need a power supply higher than 460Watts?Any suggestions?
Any suggestions/additions/recommendations on the above spec will be really helpful.
deadman
deadman
