speed_seeker
Which is the more reliable brand, the reviews on Takealot are good but I cannot find many reviews elsewhere. Both require neutral wires, and both look like they fit SA switches.
Thanks chickenbeef, are you happy with them, are you using them with Alexa or Google Assistant? Do I need to flash them, is that just to get it to work with different apps apart from Smartlife?I have a few Qualitel 1, 2 and 3 gang switches. The 1 and 2 gang models have a TYWE3S chip that's flashable, the 3 gang has a WB3S that's not flashable.
I bought them at the same time, not sure if the new ones all have WB3S now.
I've got sonoff's through out the house. Over the past couple of years one has needed replacing.Which is the more reliable brand, the reviews on Takealot are good but I cannot find many reviews elsewhere. Both require neutral wires, and both look like they fit SA switches.
Thanks, I installed two 1-gang switches and one 2-gang switch (Qualitel), I added them to the Smartlife app and they integrated with Alexa and Google Assistant seamlessly. They do make a bit of a "clunk" noise when turning on and off though.I am happy with them. I am using it with Home Assistant which is integrated with Google Assistant. Not sure about Smartlife.
You don't need to flash them to use it with Google Assistant.
Do the Sonoff switches make a clicking sound when you turn them on or off?I have 2 and 3 gang Sonoff switches with dead standard firmware, working well for the past year. I have all IOT separated on my network.
Here are some pics of the install of the 2 gang switch, we needed to pull a neutral wire throughThanks, I installed two 1-gang switches and one 2-gang switch (Qualitel), I added them to the Smartlife app and they integrated with Alexa and Google Assistant seamlessly. They do make a bit of a "clunk" noise when turning on and off though.
Have not tried the Sonoff's yet. I have only installed 3 Qualitel switches so far, I like the look and feel of them, I prefer the glass panel in front to the ones that are plastic. The ease of integration with Smartlife to Alexa and Google Assistant is also a plus. I have just bought Qualitel switches for all the remaining light switches in my house.Are the Sonoffs also backlit?
Yes they are. In the eWelink app you have the option to turn off the wifi indicator. I don't know if you can do this in HA as well.Are the Sonoffs also backlit?
You're off to a good start! Share pics of the end result and your review/experience of these switches.Have not tried the Sonoff's yet. I have only installed 3 Qualitel switches so far, I like the look and feel of them, I prefer the glass panel in front to the ones that are plastic. The ease of integration with Smartlife to Alexa and Google Assistant is also a plus. I have just bought Qualitel switches for all the remaining light switches in my house.
My pics still show the switches with the protective plastic sheet on the front, will remove once I have tidied up around the switch with PaintersMate
I found "frames" for the Sonoffs (3D printed); not sure if you get those for the Qualitel switches too. It takes the effort out of finishing off the area around the switch.My pics still show the switches with the protective plastic sheet on the front, will remove once I have tidied up around the switch with PaintersMate
