Have a Quality Superflo pool pump. Came with the house we bought and i see there's plenty debris in the pump basket.
Problem is I can't get the basket out!
It's one of those with a top screwnut, which is a metal bracket that swings to the side if the screwnut is removed. The problem is that the screwnut is removed - the swing arm wont budge - the clear plastic top cover is under the swing arm and it seems to be sealed.
Used a claw hammer to pull up the plastic lid - it released some pressure (assumed its a negative pressure problem) - but alas nothing - that bracket will not budge.
I assume many people have this pump - its quite popular. Anyone else know how to crack this open (short of a sledgehammer)
PS: This is the type of pump with the screwnut/bracket setup: https://www.takealot.com/0-75kw-poo...eMlbcbyXl_saEsW6gxkaAudKEALw_wcB&gclsrc=aw.ds
