The LG 47LV3530 47" 1080p LED TV packs a vast amount of great high-end specs and convenience features into a seamless glass panel which looks like it was retro-engineered from a trip to the future.
The combination of Dynamic Contrast (which delivers a ratio of 8,000,000:1) and full 1080p HD makes the 47LV3530 a remarkable TV by any standard but we're just getting started. LG hasn't sacrificed creature comforts for strong specs.
Since every room is different, the 47LV3530 employs an Intelligent Sensor to automatically calibrate the optimal settings to match the color and light level of your specific space. The 47LV3530 is also ISFccc Ready, meaning that it can be professionally calibrated to your specs and the settings saved as a preset. You can switch back and forth from the factory settings with the push of a button.
The 47LV3530's wide connectivity, which includes 4 HDMI connections, enables 1-cable connection of your A/V components. The two USB inputs allow you to share JPEG slide shows and videos (including DivX HD) with your friends. Real Cinema technology displays HD movies just as they were shot in 24p (24 fps) for an authentic theater experience at home, while Clear Voice II balances the voice channel in relation to swelling music or background noise, so you never miss a word of dialogue.
In addition to all of the above, the 47LV3530 is loaded with convenience features like a sleep timer, parental control, closed captioning A/V input labeling and favorite channel programming. Lastly, Energy Star compliance means that you'll be saving money while helping to save the environment.
So Smart, It's Simple
A revolutionary easy way to access limitless content, thousands of movies, customizable apps, videos and the best of the web all organized in simple to use interface. And, when you can just point and choose selections with LG's unique motion-controlled Magic Remote, it's even simpler. That's what you get with an LG Smart TV experience, the next generation in entertainment organized within a simple interface
Prepare To Be Dazzled
Want deeper blacks and richer colors? LG's LED Plus technology provides even greater control of brightness through local dimming technology to deliver better contrast, amazing clarity and color detail, as well as greater energy efficiency compared to conventional LCD TVs
Cut Loose When You're Wi-Fi Ready
Getting your LG TV connected to NetCast Entertainment Access and other online content is easy when you are WiFi Ready. If you have existing wireless broadband, setting it up is simple and you don't need to worry about messy wires
Make Digital Devices Compatible
To build a digital network, you need digital devices. That's obvious. But unless those devices are compatible, it won't be much of a network. DLNA Certified devices work together
Less Blur. More Action
TruMotion 100Hz technology lets you see sports, video games and high-speed action with virtually no motion blur. Now your TV can keep up with your fast- moving entertainment
Double The Detail
This stunning picture is the reason you wanted HDTV in the first place. With almost double the pixel resolution, Full HD 1080p gives it superior picture quality over standard HDTV. You'll see details and colors like never before
Energy Star Qualified
Earning the Energy Star means a product meets strict energy efficiency guidelines set by the US Environmental Protection Agency and the Department of Energy. For TVs, it means they save energy both in standby and active (when they're on) modes. Energy Star qualified TVs use about 30% less energy than standard units
Video Features
XD Engine: Yes
Aspect Ratio Correction: 5 Modes
Just Scan (1:1 Pixel Matching): HDMI: 1080p/1080i/720p, Component: 1080p/1080i/720p, RF: 1080i/720p
Color Temperature Control: 3 Modes (Warm/Medium/Cool)
1080p Source Input: HDMI: 60p/30p/24p, Component: 60p/30p/24p, RGB: 60p (WXGA)
Picture Mode: 7 Modes (Intelligent Sensor/Vivid/Standard/Cinema/Game/isf Expert 1/isf Expert 2)
Picture Wizard II: Yes
AV Mode (Picture & Sound): 3 Modes (Cinema, Sports, Game)
24p Real Cinema (24p 5:5/2:2 Pull Down): (24p 5:5/2:2 Pull Down) (HDMI 1080 24p)
Expert Mode/ISFccc Ready: Yes
Audio Features
Dolby Digital Decoder: Yes
Surround System: Infinite Sound
Bass/Treble/Balance Controls: Yes
Auto Volume Leveler: Yes
Sound Modes: 5 Modes (Standard/Music/Cinema/Games/Sports)
Clear Voice II: Yes
Connectivity
LG App Store: Yes
Web Browser: Yes
Wi-Fi Ready: Yes (Adapter Included)
DLNA Certified: Yes (Movie/Photo/Music)
Windows 7 Certified: Yes
SIMPLINK (HDMI CEC): Yes
Wireless HD Ready (2D Only): Yes
Special Features
Smart Energy Saving: Yes
Intelligent Sensor: Yes
LG Smart TV: Yes
A/V Input Navigation: Yes
Input Labeling: Yes
Child Lock: Yes
Closed Caption (CC): Yes
Convenience Features
Auto Tuning/Programming: Yes
Channel Add/Delete: Yes
Favorite Channel Programming: Yes
Auto/Manual Clock: Yes
On/Off Timer: Yes
Sleep Timer: Yes
Auto Off/Auto Sleep: Yes
