Radeon 4830 Fan not speeding up.
Rendier
Port Elizabeth
Ok guys...
So I updated my bios to the latest version along with the latest ATI driver for my card.
The problem is that the games freezes BUT... it does it after a long time... 40 min or so... so at least its not immediate anymore.
Another thing is that when I start a game for the first time after not playing for a while the screen will make stripes across the screen like if you were to hold a cellphone next to it whilst it rang... then the screen goes black and comes back on a couple of times and then its fine...
Now I noticed that my fan on the Radeon doesnt change in speed from Desktop to in game use. I have tried changing it in Catalyst and also with a third party app but even when I change the data to increase the rpm it doesnt do it.
It just stays at the same idle speed.
WTF>
most probably your have the powerplay issue.
what i get on my 4850, randomly some games would go black or vertical stripes over the screen and this is due the fact that the initial batches had a bios bug, which made the fan and powerplay not work correctly.
what you can try is,
  • disable power saving in control panel
  • flash with a bios that has correct idle speeds (i used msi one from one the links below)
  • enable overclock, and increase with 1mhz both core and memory (currently i just have it enabled, and didn't change the speeds at all)
  • do the fan thing (here)
http://forums.anandtech.com/messageview.aspx?catid=31&threadid=2206426
http://www.tomshardware.co.uk/forum/page-254284_15_0.html
http://forums.guru3d.com/showthread.php?t=268131
http://www.hardforum.com/showthread.php?t=1319658
http://www.techpowerup.com/vgabios/...ufacturer=&model=HD+4850&interface=&memSize=0
