Dolby
- Jan 31, 2005
I bought one of these last week and set it up.
On my LAN, it seems alright and works - I can login into the controller and it breaks out into the Internet to get a weather forecast. But issues start when it's off the LAN (ie I'm sitting at work) and I try access the controller. Do you think the issue could be my own network? I have cameras and smart light switches that work anywhere in the world though - I didn't have to set anything extra : they just worked!
Basically : On LTE, it seems to access once - but no Internet breakout. The second time, it won't even access the controller and spit out a Network Error. When I get back on the LAN, it accesses the controller but still no Internet break out ... if I reset everything, I can access the controller and break out to the Internet once again from the LAN.
Someone mentioned DynDNS?
They mentioned that the camera and the lights, use cloud services ie I login - whereas the irrigation, I don't?
EDIT : Reposting in the Networking section too
