DDR133? Surely you mean PC133 right?
Have a look right at the beginning when the PC POST's, see if it displays 128MB or 256MB (131xxxkb or 262xxxkb) RAM.
If it only displays 128MB and you have a 256MB stick installed then either:
a.) the motherboard may only support 128MB modules.
b.) the motherboard may support 256MB modules, but single side instead of double side or vice versa.
c.) the motherboard may support modules only of a certain configuration (16x16, 8x32, etc).
d.) you may need a BIOS update.
e.) try another DIMM slot.
Take out the old RAM and see what happens. Possibly the new RAM is broken, it happens.
Swap the RAM around and check if it makes a difference
I got a simple solution. Maybe the RAM he bought isn't 256MB but 128MB afterall?
Wow, what did that PC133 cost you? The last time I saw prices for a 256MB stick it was around the price of a 1GB 800 stick.
I've heard of this problem but right now I just can't put my finger on it....
I bought it at PC Int, they always have been trustworthy!
The stick is only one sided, with 8 "chips". Is this a 128 or 256?![]()
