Were there any rat poops in the filter housing?
You dont want them eating your wiring. That is costly. Warranty and insurance doesn't cover rat damage
... rats eating copper wire ...
Or is it to get back at the Cat 6?
no idea. they didn't say anything. but to be honest, that doesn't look like rats to me. too much in the middle and in the same place. also, after the service (which was its first) all the torque steer seems to be gone, which was a big issue for me the first 20,000km
Torque steer? What car do you have?
How the hell are you driving that you are getting torque steer?
You should only ever feel that if you are doing flat out hard launches. Otherwise it's not torque steer.
Check the intake pipe for any loose pieces of wire that could have gotten stuck in there.
The shape of that looks like something that was floating around that was loose in the intake side.
The bends on the filter media indicates that the air intake to the engine was more than what the filter allowed and started to make a vacuum and started sucking the filter inwards.
The color of the media looks if it from the GUD/FRAM stable undercover for the OEM.
Well that ^^^ i snot entirely true. I get plenty torque steer on my ST.
Yes because it's too much power for a FWD car.
And as Fanie pointed out now he also drives one and in the fashion I mentioned so that explains it all.
Engine in the Polo GTI is a lot smaller isn't it?I had a Polo GTi, 2011. Same-ish 0-100. no torque steer of any kind.
Any Golf GTi owners here who have torque steer?
