REALLY NEED HELP WITH TAR.BZ2
I've already gone through that. For some reason it doesn't work. Can I perhaps ask you to do it for me and maybe email me the .deb file?
Sorry man. I don't run Ubuntu (or GNOME for that matter). Why doesn't it work? Did you uninstall the old globalmenu?
After running ./autogen.sh --prefix=/usr --sysconfdir=/etc what are the last couple (10 or so) of lines? Are there any errors?
From all the libtool errors I'm guessing you haven't installed libtool. Install it then get back to me.
Okay looks like the problem seems to be with compiling tests. Try compiling using
./autogen.sh --prefix=/usr --sysconfdir=/etc --disable-tests
I'm unsure of what's causing this unless it's really a syntax error. Try running 'make clean' then do the ./autogen stuff again.
