InTheCube
So I'm in the market for a solar geyser. I don't know too much, just doing the initial research / legwork before I start getting quotations. Any and all advice will be appreciated. I'm in JHB, and I think I need about 300 litres. This is for a household of 5.
A few questions I have:
- ls there such a thing as a Smart Solar Geyser? Something with maybe a network port or built in WiFi to monitor the geyser, or configure settings (if any?). Don't want to buy a dumb solar geyser if there are smart ones available, if the additional cost is reasonable and the extra functionality useful.
- What happens to the solar geyser if I am away for say 1-2 weeks or more? Can it be switched off? I've heard some people mention that you need to cover it with a blanket otherwise you can run into issues, but this has its own issues if there are strong winds. Are there no solar geysers that handle this automatically, or can be switched off, or have a motorised cover to block out the sun? Or have I been listening to nonsense?
- What happens if you have a week of bad weather with no/little sun? Can these geysers switch to mains supply in order to heat the water? Can this be disabled altogether? Or enabled/disabled remotely via an app / smart functionality? If I plan to eventually go offgrid, can the solar geyser tap off battery storage for bad weather days? Can some sort of limit be set for this so as not to deplete my batteries on water heating?
- What is the general rule about payback period on a solar geyser? Can I recover my investment in say 5 years just from the savings on electricity charges?
- Are there any insurance approved geysers that someone can recommend? I know Standard Bank Insurance will only cover a solar geyser if the installer/supplier gives you a 10 year warranty on the geyser (so what is the point of insurance on the geyser then?) and produces a COC.
- Can someone recommend some brands and/or installers in the JHB area?
- What ballpark figure should I be looking at for a complete solution with installation?
