Remote access possible on Afrihost Mobile?
nic777
Johannesburg
Hi all,
Has anyone tested whether remote access to Afrihost Mobile is possible?
That is, have you been able to use to connect to your VPN, or PC or network camera via port forwarding when using Afrihost Mobile on the remote site?
I have set it up now and not seem to be working. Newish router so also checking if its that.
Afrihost support said "The Afrihost APN Should not be restricted in any way, and should allow any incoming connection.". The "should" part makes me unsure so wanted to hear if anyone actually got it working?
