Remote desktop connection from pc to pc using only a 3G connection only
ngwenyas
Hi guys
I have a 2 3G cards, both sim cards activated with the unrestricted APN. I want to make a remote connection form the one pc to the other.
Can i have the steps? Dyndns installed on both pc..i have my I.P adresses and have them setup in my tcpip settings... the unrestricted apn is setup on the vmb software on both pc's....What do i do from there? do i use remote desktop connection? Note that the pc im connecting to is my home pc with windows vista:wtf: and the laptop im making a connection from is my work laptop and it's on the domain
thanks
Just open Remote desktop connection and type in the Dyndns name of the other pc, if RDP is set to allowed on the pc it should work, and make sure your firewall (if you have one) allows incoming connections on port 3389...
