So my GPU recently died - the fan literally fell off (without me noticing) and thus overheated. This was while gaming and the PC froze. I restarted, played more, froze again, at which point I opened up and checked things out and found the fan issue.
I have removed the GPU, but have an issue now where I still get random freezes, as well as at time, on boot, the PC will fail to recognise the SSD which Windows is installed on. Sometimes it works, sometimes not. Either way, it isn't stable.
I have tried removing all other HDDs, different SATA ports and different SATA cables - same issue.
So there's clearly something up with the drive.
Advice needed is how best to proceed. Do I install Windows on a spare drive and use it to scan this one? Do I attempt a repair install?
