Repairs to led screen
MR.C
I got a Samsung Syncmaster P2350 lcd (not autocorrected led) cheap but it switches on and gets dim after about 2 seconds.
I opened it and saw this :
Any idea where to get it repaired in Pta/Centurion, hopefully cheap.
Or to get the part locally...
Any help will be appreciated.
What do you see? I see some discolouration and possible melting but that doesn't mean it's the cause of the problem.
Thought it was the problem. I don't have a multimeter so jumped to the conclusion with my limited experience
My Samsung (different model) had the same problem, the inverter transformer blew. I ordered the transformer on ebay for cheap, and 3 weeks later it was a simple soldering job to replace.
Samsung wanted to charge me several hundred Rand for a replacement board, which would have taken weeks to be in stock with them anyway.
Definitely a power issue. If it was a CCFL issue it would flicker like a blown fluorescent lamp.
Any swolen or leaking caps?
The part you are looking for is a backlight inverter transformer...
http://www.ebay.com/itm/1PCS-Inverter-Transformer-QGAH02113-For-SAMSUNG-LCD-/251236095598
Alternatively you could replace the entire power board. You're looking at about R1000 including shipping.
http://www.ebay.com/itm/Samsung-249...859292?hash=item35e166861c:g:H1EAAOSwMmBV191f
I assumed it was caps, screen at work had same problem but they all look good.
2 seconds to blank is a typical problem when:
- one of CCFL's is blown or
- inverter board is faulty
In your case high voltage transformer looks fried. Meassure resistance on the both secondary windings. It should meassure the same, typically around one Ohm. If resistance differs more than 5% (or is floating), then you must replace transformer. The link given above is correct.
I had 2 second to blank syndrome on my B2330. Replaced transformer and now the board is trying to burn another transformer. There must be also faulty CCFL, but didn't check it yet, as Samsung made clever decision to make access to CCFL's difficult. I have to disassembly entire panel to replace CCFL! I spoke to Pinnacle service guys, Samsung authorised service centre will not service CCFL's, they will replace entire panel.
Pinnacle Micro in Midrand is a Samsung authorised centre. They have good service personel.
Try to replace tranformer first. If doesn't help, then don't throw monitor away, I can give you an offer - looking for spare CCFL's for my monitor. When you get back from Pinnacle, you can drop it in my place in Midrand. Sorry to hear about, I like these old CCFL's backlit monitors, there are better for my eyes.
bumping this old thread...
can someone please guide where to get these in gauteng area?
Hi. Sorry for the late reply.
I have a few of them.
PM me if still interested.
I still have 2 remaining, if anyone is interested, PM me.
