Replacement phone for P8 Lite?
marco79
Back in CPT!
My sons P8 Lite was stolen a few weeks back. Which phone would be a suitable replacement for it?
I was thinking of getting another P8 Lite or a Samsung J5 on a uChoose Flexi 200. The P8 Lite I bought cash and I bought him just over R100 airtime a month which he converted to data. On this contract he could convert the airtime to about 1Gb per month.
Maybe I should give him the option of the P9 Lite at R250 pm but that is on a uChoose Flexi 110.
Any other options?
The P9 lite is a great phone its price per spec's is unbeatable I would definitely go that route. The p9 lite has full HD screen, better processor and more ram its just a better phone then the other two.
He also used a p8 lite so no major learning curve to go for the p9 lite.
With the uChoose Flexi 110 you may have to pay a bit extra to be able convert the airtime to data and make sure you have a cut off point once the R110 airtime is gone (i think you pay extra for this from vodacom). Ask the guys there just to make sure
My wife is on a uChoose Flexi 350 contract. No charge for converting airtime to data, and it cuts of outgoing connections when the balance is R0.
Redmi note 2, will be a decent replacement, bigger screen, higher res.
Have you considered the new Telkom freeme packages? I am currently investigating that for myself.
Edit: also looking at p8/9 lite
