I'm hoping someone can help me out with a problem i'm having.
I've got a 19" LCD panel which only has a DB15 (Standard RGB/VGA connector) to which I would like to connect various other video sources such as Composite, S-Video, Component etc. (What else is there?) for connecting DVD players, cameras etc. directly to the panel (IE without using a PC).
I've been goolgling and searching for a device to do this which has only lead to headaches and some serious confusion in some of the forums i've read, as most of them deal with converting only component to RGB.
I'm pretty sure it's going to require more than just some sort of cable, probably some kind of converter, although I might be wrong.
