So everything was going fine earlier.. My ping was fantastic on all accounts and i was all smiles
Until around 21:45 when things started to go a bit south. So i quickly did a ping test or two as well as a trace to mybroadband and below are my results:
Trace was done using the Openweb account
Tracing route to
www.mybroadband.co.za [41.203.21.137]
over a maximum of 30 hops:
1 168 ms 170 ms 173 ms 196-210-170-129.dynamic.isadsl.co.za [196.210.170.129]
2 164 ms 177 ms 165 ms cdsl2-ctn-vl2276.ip.isnet.net [196.38.72.125]
3 206 ms 216 ms 188 ms 196.35.115.136
4 209 ms 198 ms 179 ms core2a-ctn-gi0-2.ip.isnet.net [168.209.6.6]
5 172 ms 163 ms 165 ms 168.209.2.130
6 142 ms 144 ms 149 ms 41-208-29-210.mtnns.net [41.208.29.210]
7 140 ms 146 ms 139 ms 196.44.0.75
8 241 ms 236 ms * rb-cr-1.za--ct-cr-1.za.mtnns.net [196.44.31.128]
9 250 ms 251 ms 244 ms 196.44.31.97
10 167 ms 213 ms 188 ms ge11-0-0.gw2.jnb6.za.mtnbusiness.net [196.30.1.22]
11 167 ms 174 ms 176 ms vlan9.hr3.jnb6.za.mtnbusiness.net [196.30.156.136]
12 188 ms 186 ms 180 ms core-router1.jnb2.host-h.net [196.30.213.108]
13 201 ms * 160 ms core-access-switch1-vlan1001.jnb.host-h.net [41.72.136.53]
14 191 ms 195 ms 210 ms mybroadband.co.za [41.203.21.137]
Trace complete.
- ping www.mybroadband.co.za (Telkom account)
Pinging
www.mybroadband.co.za [41.203.21.137] with 32 bytes of data:
Reply from 41.203.21.137: bytes=32 time=197ms TTL=50
Reply from 41.203.21.137: bytes=32 time=181ms TTL=50
Reply from 41.203.21.137: bytes=32 time=182ms TTL=50
Reply from 41.203.21.137: bytes=32 time=168ms TTL=50
Ping statistics for 41.203.21.137:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 168ms, Maximum = 197ms, Average = 182ms
- ping www.mybroadband.co.za (Openweb)
Pinging
Reply from 41.203.21.137: bytes=32 time=142ms TTL=51
Reply from 41.203.21.137: bytes=32 time=137ms TTL=51
Request timed out.
Reply from 41.203.21.137: bytes=32 time=165ms TTL=51
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Minimum = 137ms, Maximum = 165ms, Average = 148ms
- ping www.mybroadband.co.za (Mweb)
Pinging
Reply from 41.203.21.137: bytes=32 time=153ms TTL=51
Reply from 41.203.21.137: bytes=32 time=150ms TTL=51
Reply from 41.203.21.137: bytes=32 time=133ms TTL=51
Reply from 41.203.21.137: bytes=32 time=135ms TTL=51
Minimum = 133ms, Maximum = 153ms, Average = 142ms
I'll do the same tests in about an hour or so and re-post the results...
