Right Click FTP
mh348
NW, SA
Does anyone know of a Program that will allow me to right lick a file and choose Send To > FTP.
It should have profiles so I can just choose where the file should be uploaded. I use FileZilla and it's a pain opening it up everytime just to upload one or two files. I need to ftp files at least 3 to 5 times a day.
if you use total comander you could do it is a command
the other option is to write a batch file that takes a file as paramater
then add the batch file to you right click menu...
you could create a batchfile per ftp site or have them all in one but i would recommend a batch file for each..
or just use open with with the batch file
ok, easily done.
open up network neighbourhood/my network places.
click on "add network place", follow the wizards....for ftp prefix the site name with ftp://
like ftp://ftp.sitename.com
fine...now go to your c drive, documents and settings, your user name, sendto folder
and open up network places...and create a shortcut from the newly created ftp icon in your sendto folder
so easy
