Romoss Power banks...
Necropolis
So I'm looking at getting one of the 20,000mah Romoss power banks - and was wondering if anyone here had used one?
Do they work well?
Are they worth the money?
I have the Sailing 6 20800mah. It was cheap and so far no issues. Due to power issues where I work, I use it to charge my mobile phones (CAT / iPhone) and my e-ciggies.
It's a bit heavy and bulky but I am used to it now.
The only downside is that it takes a while to recharge (I charge it via USB on either my laptop or work desktop).
They're good and worth the money.
Their 20000mAh unit is a bit heavy and big though. It also takes a good couple of hours to charge fully from flat.
i own 3 of them and they just work and work and work and work and work and work and work...
Thanks for the feedback :D
I recently bought the 20,000mah unit and trust me, I could not be happier. Charging two units at the same time, and doing so 2-3 times before having to recharge the unit again .... what a pleasure.
It's a bit heavy (nothing you can't handle) but if you don't try and sneak it into your wife's handbag when you go out for the day, you'll be fine.
Good value for money
Their products are great-
Only once had an issue where the device wouldn't charge but it seemed to sort itself out.
I have one and it works perfect. No issues at all. I would definitely recommend them.
I won the 20 000 unit right here on MyBB.
It is an awesome unit... and as I look on my desk to find it, I see that my son has stolen it again! :mad:
Have one at home. Bulky and takes a long time to charge, but that is the only downside. Bought it off Takealot about 2 years ago. Bought some smaller other brands and they work just as well.
have a 16000 and it works perfectly.
Charges my S7E and my wifes G4 several times before it runs out of juice.
I have the older solo 9 20 000mAh one.
much bigger than the sailing 6, a friend in the office has one of those.
and other than the 13 hour charge time (to be expected honestly) there is no complaints.
wife has a different brand 10 000mAh power bank, and honestly even though its much more portable its just not worth it.
get Romoss.
I would actually want to get another, smaller one.
the idea is, have the solo 9 in a bag, so when I am at a desk, or table, plug it in and charge everything. but when I am walking around playing Pokemon go, have the smaller size one to keep the phone going while being able to walk, the solo 9 does not fit comfortably in the poket, and you look like a twat.
if anyone spots any god cyber monday deals on Romoss Products, please share them...
get Romoss.
Get one of the new Poly ones, they use a polymer battery and apparently are much less bulky and lighter. Mine is arriving next week apparently.
