Hi, My Adsl router is working perfectly in terms of making a connection to the internet BUT I'm unable to get into the router settings via my browser.
Router is a Telkom ADSL Router POTS (1 Port)
I get a "504 Gateway Timeout" when I try and connect to the router although my connection to the internet works perfectly. I'm using the default gateway address to try to connect to the router. I did this in the past without a problem.
My firewall and anti-virus are turned off.
Called Telkom and they said all I can do is hard reset the router via the little pen hole to reset to factory settings BUT there is the chance I will be unable to use setup the router again if the settings are still inaccessible after the hard reset.
Anyone have any other ideas please?
