SA Busy Tones
beesknieg
Bloemfontein
Guys, i have a Grandstream GXE5028 acting as a Gateway to my AsteriskPBX, calls get dropped after about 30 seconds over the Grandstream and i know my problem is with the Busy tones can anyone provide me with this info
Here are my current settings :
Dial Tone - f1=380@-24,f2=415@-24,c=0
Ringback Tone - f1=400@-24,f2=365@-24,c=420/1980/420/180
Busy Tone - f1=400@-24,c=500/500
And also another problem i just can seem so resolve :
I have a Vodacom SIP, phoning to another Vodacom SIP (087XXXXXX ) and the call will always drop at exactly 45 seconds, I have checked my NAT, Fireweall Asterisk etc.
Here are my SIP trunk Settings :
[2787XXXXXXX]
disallow=all
username=2787XXXXXXX
type=friend
secret=Mypassword
qualify=yes
nat=yes
insecure=invite,port
host=41.0.26.166
dtmfmode=RFC2833
context=from-trunk
allow=g729
BTW the PBX does the PPP to Vodacom
Thank you for the reply, after your suggestions I had a look at ISDN I think we will be converting
What ISDN gateway would you suggest, my PBX is in a Virtual environment so I can’t use the Digium cards directly on it
The Patton gateways are pretty good, a little complicated to setup, but they work well.
