i also got a P4 3.0ghz, should be running at about 26-28 degrees celsius on stock cooler. thats how much mine runs on.What are safe temps for an ATI 850XT and P4 3ghz?
My CPU (I think it's my CPU, SpeedFan doesn't specify) reached about 65 running SuperPI. And about 50 when under no load.
Iirc coretemp only works with C2D CPUs.
What's the safe temp for my mobo please? I'm playing COD4 and the mobo is recording between 50-55 degrees, when idle it's @ 48-49 degrees. The asus probe has the mobo's default temp set @ 40 degrees !!! Whereas the probe has the Q6600 default @ 65 degrees.
Thanks in advance![]()
