sahara 5.1 speaker with dvd player help
killadoob
South Africa.
so i got my new vga card and with them came these speakers
my question is this can i use these speakers for my enzer dvd plr i tried to plug everything in and nothing worked :(
ITS LOOKS LIKE ITS ONLY MADE FOR PC but i thought maybe someone here thinks otherwise
If it is a self amplified speaker set it should work (must be self amplified if its a 5.1 system. audio out from the DVD player goes to the souce input lead of the speakers. Connect the speakers together as per manual and switch everything on. Should work.
wont work kd..
buy yourself proper speakers;P
lol i got a 2.1 mircolab setup, it's got the normal line in from my pc, but its also got and composite in, so i can link up my ps2 to in. and this thing pomps, the sub is killer
more importantly what vga card did you get :D
