Android 5.1.1 is out in several countries for the Galaxy Note 10.1 2014 edition (P605).
My Note 10.1 2014 edition (P605) on Vodacom has been on Android 4.3 since 2013.
It's now the third year with this tablet stuck on Jelly Bean (Android 4.3).
When are we getting Android 5.1.1 in South Africa on the Vodacom network?
You've got a Samsung device and you're hoping for updates? That's hilarious
I won't rush into buying another Samsung device again, I have a Z3 Compact- love it, regular, timely updates, zero bloatware, responsive
and then i have this piece of shyte galaxy 10.1
I downloaded the latest 5.1.1 I think from Sammobile. Really worth the upgrade and has given the device new life with the refreshed touchwizz that is much leaner.
Are you also using the P605 (LTE version)?
Which firmware on Sammobile did you use, i.e. for which country, for 5.1.1 to update successfully?
Does the S-pen still work after updating to 5.1.1?
This one:
http://www.sammobile.com/firmwares/download/56501/P605XXU1EOI5_P605OXAEOI5_NEE/
Instructions are on the page.
Yes S-pen still works and you get all of the new 'Note' features.
Thank you very much.
Before I extract (unzip) the firmware file and extract the Odin ZIP file (as indicated under the instructions on SamMobile), do I need to root the device first?
If yes, can you please suggest how or a link to root the P605.
