Samsung S6-"Mobile Data" shortcut missing
Lionking_
Klerksdorp
Good evening
I'm having the Samsung S6, and tonight I noticed something. Right at the top, where you have your little taskbar with shortcuts to "Wifi", " Torch", "Sound" etc.......I noticed that the shortcut to "Data on/off" is missing. Now I cannot seem to get it back, as I googled for how to fix it, but nothing is helpful. I hope there is someone that had the similar problem, and would like to share in how to fix this problem.
Thanx
Chris
Hahaha, sorry Lionking but that's hilarious, no offence it's just such an unusual thing to happen :D
Hopefully somebody here csn help. GL.
So much win in this thread. It isn't even in the Android section.
You might have to go into one of the Samsung stores and have them sort it out.
Good evening
Thanx
Chris
I too just lost my data toggle. It was there before I made some build.prop edits to improve multitasking. It seems that many others are having the same problem.
Did you by chance also edit your build.prop?
Hi there
No, I was busy switcing between Data and Wifi when I was busy with an router to test wifi. I got home and want to change back to data, and "POEF", gone it was. Thanx for your reply. R12000 and this stupid thing happens.
Thanx anyway
Will take it in to MTN, but with the people and services you receive everyday, I doubt that those "assistants"
will know what to do. Maybe they suprise me
Chris
Here's a silly question but have you gone into settings and then into notification panel?
That's where you set what appears along the drop down menu.
Mine is there
Good evening
Thanx
Chris
Same thing happened to mine :confused:
http://mybroadband.co.za/vb/showthr...uts-disappeared-on-my-Samsung-Galaxy-S6-today
Worldwide phenomenon! LOL
The latest update in Software caused it.
Sadly, my S6 was in for repair and Samsung themselves updated the software ARGH! now to toggle to setting each time i want to swtich data on or off ... ist world problems ...
Fix
Good evening
Thanx
Chris
Install all 3 apps and add shortcut to toggle on app. After that uninstall the app.
https://www.dropbox.com/s/sfff7lobrj2qh76/WifiHotspotToggle.apk?dl=0
https://www.dropbox.com/s/18r5hmgpg4nfi30/privatetogglefix.apk?dl=0
https://www.dropbox.com/s/yvrle4egsnrx4le/fixdatatoggle.apk?dl=0
Fixed!
Good morning.
I hereby officially thank you for repairing my "data" problem I had on my Samsung S6. I think that you must send your "CV" to Samsung and apply for an CEO job there. Your files had fixed my phone and all is up and running.
Thank you again, and nice to know that there are people still helping each other!!
Much aprreciated
Chris
FIXED FIXED FIXED FIXED!!!!!
