I just got a new Western Digital 250gig sata2 HDD, I have a MSI K8n Neo2 platinum Motherboard, everything is installed right when I use my other HDD to boot windows, it sees the HDD fine, I wanted to install windows on the new 1 & so I go into dos,into the windows setup,select the HDD,format & it copies the setup files over, then you reboot and it says "Cannot load operating system", if I try to boot windows then with my other HDD, it says hal.exe is corrupt, please reinstall
Has anyone had this type of problem with this motherboard and loading windows on a SATA hdd or know of any way to fix this
Thanx in advance
S1ght
Thanx in advance
S1ght
