Scheduling Mobile Partner to connect
whatwhat
Hong Kong
Hey,
Is there a way I can schedule Mobile Partner to connect on Windows? On OSX I used Automator but cannot find something similar on Windows (7)
Need to have the computer dial up just after midnight due to the midnight surfer hours data I got left. It would seem that it doesn't do an automatic swop over when left connected all the time on 8ta.
No comment on Mobile Partner, but you can use Windows rasdial.exe (or rasphone.exe) to dial your connection and any scheduling software to run it.
You can also ask ginggs to add autodial option to his small and excellent dialer. I don't know why nobody asked for this option yet. :)
With the latest MDMA beta you can select to use modem dialing or NDIS (for newer devices).
