Schema: 12volt to 9volt voltage regulator
Thor
Bellville
I currently have solar panels charging batteries via a charge controller and then I have one of my routers connected to the load of the charge controller since both the charge controller and the Mikrotik is 12volt.
However my VDSL modem (Netgear) is 9volt.
I want to build a 12volt to 9volt DC to DC inverter.
Any idea what parts I need (Yebo electronics is down the street.) and I'm comfortable soldering, just need a schema.
Get a 7809 voltage regulator, depending on the model should handle up to 35vdc in and give 9vdc 1A out. Cost around R7 each. You can connect them in parallel to achieve a higher amperage handling. Also get a small heat sink.
That is neat, I think I will buy the stuff to build this one as well, I like the DIY approach.
They're quite old tech, but get the job done and are commonly available. Just remember to use a heat sink as they generate a bit of heat under load, an old CPU heat sink without the fan works great.
What is the advantage of the circuit I was looking at earlier vs this approach?
I would hazard a guess that your circuit and perhaps more is built into the TSR.
The TSR is way more energy efficient and uses frequency switching to step down the output - but is a more expensive component. The 7809 and xx184 circuit are both linear regulators, they are cheaper, but generate heat due to inefficient conversion.
There are quite a few other makes of DC/DC step down converters like the TSR out there, you would need to confirm what your local electronics shop stocks.
Why don't you just buy a buck boost converter of one the Chinese sites.
They are like R35
ZAR 32.70 | DC CC 9A 300W 150W Boost Converter Step Down Buck Converter 5-40V To 1.2-35V Power module
https://s.click.aliexpress.com/e/cHD7qKCo
That is cheap for 9amps output, but probably an overkill for the intended load. I would also be cautious with cheap Chinese power products (think MTBF due to cheap components).
Have you tried to power the VDSL router from a 5V power bank? An Adata 5000mAh power bank costs R130 on Loot and a 10000 about R190.
https://mybroadband.co.za/forum/threads/router-battery-backup.993476/page-15#post-23143044
Alternatively you could just purchase 4X 3A silicon diodes and put them in series in the power lead. Each diode should have a forward voltage drop of around 0.7~0.8V i.e. 4 in a row will drop the voltage by 4X 0.8 = 3.2V. 1N5401 diodes should be suitable and cost around R1.00 each.
http://www.mantech.co.za/Stock.aspx?Query=1N5401and
A leas acid battery can swing between 14v and 10v , with doided output will follow that swing less volt drop
I wonder if Yebo will have a TSR?
If not where in Bellville can I get it?
Went to Netram best damn service there is! Replies within 2 minute on E-mails and incredibly cheap especially Raspberry Pi and Arduino, I mean they where product for product 40 to 70% cheaper than Yebo Electronics.
