Serial over IP devices
JayM
Anyone know where I can find a 4-port serial-over-IP device. I need serial ports inside a few VMs.
if you buy a pci serial port card would vmware not let you expose the hardware to the guests too? like you do with usb ports.
What VM software do you use? Serial ports are the easiest thing to map to a Virtual session - the host serials should work.
