hello123456
- Nov 5, 2012
Hello I have an issue regarding setting up an Access point in my house.
I have a router that is working perfectly fine with an SSID "Router" on channel 6 the IP address of this router is "193.160.1.1." With a DHCP pool from 193.160.1.2 - 193.160.1.100'
I have run an ethernet cable through my house to an AP with an IP address "193.160.1.254" with an SSID "Router" on channel 10.
I am able to connect to either perfectly fine. But unable to roam from one to the other. My devices will stay connected to the one i originally connect to unless i got to settings and click on the name again, it will then pick the stronger signal.
How am I able to make my devices roam always picking the stronger signal? As the WIFI ranges do overlap.
