Setting up SIP on Asterisk with Liquid Telecom
kitkat+
Hi Guys
I see that Liquid doesn't provide any credentials to authenticate. They only provide the IP address and a SIP proxy.
Has anyone set up Asterisk with a Liquid trunk before? I would appreciate your typical setting.
Kitty
This is from my notes back in the Neotel days... You will most likely need a second nic that you IP on the same network as the SIP Proxy, then do the below.
Neotel Trunk over Neotel Fibre, this is a user trunk no reg is required, we were given a sip server address on the same network as the VOIP Server in this case 192.168.243.10
Trunk name 011XXXXXXX
username=011XXXXXXX
type=friend
secret=011XXXXXXX
qualify=yes
nat=no
insecure=very
host=192.168.243.10
fromuser=011XXXXXXX
dtmfmode=rfc2833
disallow=all
context=from-trunk
canreinvite=no
allow=g729
