Setting up Wireless repeater
Slaught3r
Hi Guys,
I need some assistance from a networking guru. I have recently installed my new internet at home and decided that it is time to say goodbye to DSTV. I have 3 TV's in my house, of which one is a smart TV connected to my XBOX - so that one is not an issue.
The other two are NOT smart TV's, but I purchased a Chromecast for one of them, which I will set up when I get home. The problem I have is that I basically have no signal in the room that I am installing. I have a spare Netgear D6200 router which I want to try and set up as a repeater. I have searched the web and found: https://www.manualslib.com/manual/575599/Netgear-D6200.html?page=112.
This is where I need your help. From the link I have to set the IP to the same LAN range - so (example) 192.168.0.x where x is the IP of the Netgear router - assuming that the primary AP is also on the 192.168.0.x range.
Looking at the screenshot - obviously I will do the repeat function on the 5ghz signal, which IP is it asking for here? The primary AP IP, or the IP I am assigning to the Netgear?
Can someone help me with a walkthrough of how to set this up?
Thanks guys.
Genisys
Hi Guys,
Thanks guys.
Phone up Cable Applications, Uniterm Direct, Scoop or Miro and ask them.for a quotation on 100m CAT 5E cable, and 10 or so RJ45'S. Run a cable. Crimp. Plug into TV and Router. Win.
Seriously, I tried a wireless bridge myself, it wasn't any good at all. Microwave would go on, then the bridge would go off.
superskully
Maybe also look at a powerline.
They may be expensive to start off initially, but worth it in the long run as its portable and easy to install.
Slaught3r
Cool, thanks. Will check out my options. Thing is I hate wires, but will check it out - thank you.
Slaught3r
Checked it out - I have that in my house already - problem being that the two power outlets you use must be on the same breaker switch.
sajunky
You didn't mention your WiFi base device, it is important that both support WDS.
+1. Cable connection is your long-term solution.
Slaught3r
Can't remember the name - its a Skyfi unit. Will check it out when I get home.
