howardb
What about this one from Thermaltake
Product Name Silent CAT
Fan Speed 1600 ?10% RPM
P/N A2329
Max. Air Flow 62.2 CFM
Frame Color White
Max. Air Pressure 2.13mm H2O
Fan Dimension 120 x 120 x 25 mm
Noise 16dBA
Rated Voltage 12 V
Bearing Type Sleeve
Started Voltage 9 V - 10 V Max
Life Expectation 30,000 hrs
Rated Current 0.30A
Connector 3 pin
Power Input 3.60W
Weight 140.0 g
P/N A2329
Frame Color White
Noise 16dBA
Rated Voltage 12 V
Bearing Type Sleeve
Rated Current 0.30A
Connector 3 pin
Power Input 3.60W
Weight 140.0 g
