Hi,
I stay in 1 of the generic Baldwin apartment units, and currently have a 700W Mecer inverter with a single battery.
The unit works perfectly for what I need, Router, TV and a light or 2.
My biggest complaint is the loud fan, as a lot of people have complained in other threads.
I really want to get a installed unit, that I can tie into my DB, and have all the lights, and 2 plugs connected to it. I really only need about 1.5 KVA, so a 3 KVA unit it more then enough.
I have some experience with the Mecer/RCT unit. They are perfect for my needs, but because I don't have a garage or other suitable separate room, the unit will have the mounted in the lounge next to the DB with the batteries in a box at the bottom.
Space is not a issue, I can so a built in box etc, so it will be neat. My biggest concern is the noise these units generate (fans etc..)
Any "silent" units on the market? I do not need a solar charge module as I can only charge the unit from the mains.
Any ideas/links? Preferably a recommendation that someone has actually seen.... well heard....
