Small ATX Case
blackstarzes
Hi guys, I have been looking for a small ATX case (not micro-atx or anything like that!). I am a student and transport my system between Jo'burg and G'town and it just takes up way too much space!
These are the components that I have and want to know if there is a box here in SA:
- Intel DP965LT mobo (294.64mm x 243.84mm)
- Intel Pentium D 2.80GHz
- 3x internal SATA HDD
- 2x internal Optical drives (i can toss 1 if necessary)
Thanks in advance :)
I'd even recommend my cheapie handle case :D It's not very big so it fits behind the driver's seat in my car :)
thanks for the replies, i was looking at that antec case, but it is a micro atx case and my mobo won't fit inside it! Anybody got any ideas?
The smallest Antec Full ATX chassis wouldbe something like the Antec Sonata3
http://www.antec.com/us/productDetails.php?ProdID=15137#
They mount the hard drives sideways, making the chassis a few centimeter's shorter than standard. plus it is REALLY easy to remove and add drives. http://www.antec.com/images/400/open_fan_S.jpg
Also, this thing will be completely silent, so you can study/sleep in the same room, no problem.
It is pricey, but comes with an excellent power supply with 3 year warranty. important when Eskom is blowing up power supplies left,right and centre.
I seriously doubt that you can get something of quality that would be more compact without having to sacrifice a Drive or Full ATX.
Be carefull with these cube cases, they do not cool properly. components that shouldn't get hot, do and break.
Antec Lanboy would be perfect. It sports easy to fit strap on handle when needed and looks great on the desktop when not transported.
