lightpixel
- Jun 15, 2019
I get 8V on the 12V system.
I will need to look at the wiring. I will check my other model also.I can’t tell - is it backfeeding DC from the batteries or AC from the inverter output?
So when the incoming mains cord is unplugged, you are getting 8V DC backfeeding from 12VDC batteries back down the incoming 230VAC power supply cord?I will need to look at the wiring. I will check my other model also.
how big are the ups units .picHello - is it normal for the input power cord (the cable from the 230VAC mains) to a small inverter / UPS to remain live after you unplug it (or after the grid drops)? In other words, for the inverter to backfeed 230VAC to its power supply cord in addition to its output outlet? If so, does it only do so temporarily or whenever the inverter is delivering 230VAC?
a bit of bleed back on a big unit is probably normal ,diodes can allow 7 volts back easy ,but there will probably be no current on it so it will just pull dead if you stick it in your eyeball .edit out of curiosity put a small globe on it ,like a park light 5 w globe and see what it does ,if it stays lit then it may become a hazardGeeWiz 2400VA (1440W) Inverter Battery Charger (UPS) - Intelligent Fan (Modified Sine Wave) 3 Stage Charger - GeeWiz
GeeWiz 2400VA (1440W) Inverter Battery Charger (UPS) - Intelligent Fan (Modified Sine Wave) 3 Stage Charger for sale online at the Best Prices! Door to Door and Overnight Deliverywww.geewiz.co.za
The bms in the batteries only balance the cells in that battery ie the 4 cells that make it a 12v batteryAgree - seems a no-brainer. But was wondering if the BMS built into the BlueNova batteries might do it automatically? More than R15k these days to replace two Li batteries…sadly…!
Will try to ask BlueNova for their advice also…
It did give me a bit of a zap when I touched the plug inadvertently…a bit of bleed back on a big unit is probably normal ,diodes can allow 7 volts back easy ,but there will probably be no current on it so it will just pull dead if you stick it in your eyeball .edit out of curiosity put a small globe on it ,like a park light 5 w globe and see what it does ,if it stays lit then it may become a hazard
its not ideal and should be mentioned to the distributor ,the back feed could become more than expected and should have a circuit to prevent it ie a resistor to bleed it off , i wouldnt be comfortable with that , without a valid reason why , and a plan to rectify it .you may also have an internal insulation resistance thats failing and could cause the whole item to become live .It did give me a bit of a zap when I touched the plug inadvertently…
Thanks - I thought the point of a balancer between two 12/13V units in series making up a 24/26V system was that it needed to be kept in place permanently to balance the voltages?The bms in the batteries only balance the cells in that battery ie the 4 cells that make it a 12v battery
I would not leave a permanently on balancer on a lifep04 battery
The balancer can't damage the batteries per se if permanently on it can however move power around in the flat portion of the graph incorrectly
You can use a balancer like this from time to time to get them in balance when batteries are over 13.8v each
Edit: keep at high voltage switch balancer on once balanced switch it of
Or buy the victron balancer that does this
That is where you balance lifep04 when cells are over 3.45v per cell anywhere else in the voltage range you are fooling yourself
It happens, I was once zapped by the plug, it's usually temporary though.Hello - is it normal for the input power cord (the cable from the 230VAC mains) to a small inverter / UPS to remain live after you unplug it (or after the grid drops)? In other words, for the inverter to backfeed 230VAC to its power supply cord in addition to its output outlet? If so, does it only do so temporarily or whenever the inverter is delivering 230VAC?
Thanks for the reassurance.It happens, I was once zapped by the plug, it's usually temporary though.
A solid 108V AC between both poles and earth.I get 8V on the 12V system.
Yes, this is true, the balancer must always be connected, the point leon was making is that with the flat curve of LFP, there is no point in balancing below the peak (13.6V), so the cheaper balancers that are "always on" actually put the batteries out of balance when they are balancing below 13.6V. I don't think its a big deal, as there are plenty of these balancers out in the field and they do the job, it just might be more practical to go for the victron one that only balances above a certain voltage.Thanks - I thought the point of a balancer between two 12/13V units in series making up a 24/26V system was that it needed to be kept in place permanently to balance the voltages?
Lifep04 batteries top balanced actually stay in balance for a few months quite easilyThanks - I thought the point of a balancer between two 12/13V units in series making up a 24/26V system was that it needed to be kept in place permanently to balance the voltages?
