Kosmik
Arb question, hope its in the rightish place as I actually couldn't find a solar segment on the forum but maybe I'll slip a sonoff into the circuit to make it all good.
Anyway....
I'm looking at doing a small solar setup in my garden for my external lights. I mentioned in another thread, that I have these nice old lampposts which are already on CFL with daynights globes but I have another idea. I built my kids a small tree house/platform thats luckily in the middle of my garden, with a lamp post next to it and a second light about 5 meters away. These used to be powered via my pool pumps db but it appears that some rodent has nommed the wires underground and I don't feel like redoing it. So, with a recent alarm upgrade, I have a spare 12V/7AH battery lying around. I've bought a small 12V/10A solar control charger and a 20W panel which I plan to hookup to a box mounted under the tree house. From there I will feed the two lights for night and the charger even has a USB segment so I may put a small hub in there to be leveraged while entertaining.
My question is, the wiring is pretty simple: panel, battery, and lights all to charger which has a controllable timer. Now, many folks have said, wire a fuse between the components which I am looking to do but the draw on the lights is going to be really minimal ( LED globes so expecting around 3-5W max power ). Is it worth fusing the lights? And do I need to use high load normal house wire as the circuit is only going to carry 12V max and about 1A? Would normal ripcord be fine? Even the panels max ouput is only just 1.3A
Anyway....
