I heard that if your phone have light sensor like my xperia v, that you can solar charge, but I tried every app in playstore and they don't work, do you know any app that works?
Another good reason to buy a decent sized memory card for your device.I installed all of them and got them to work together for increased charging. A single app on its own just cannot deliver enough charge. Cannot recall the last time I used an actual charger.
Does your phone have a light sensor, or a solar panel?
It got light sensor
Did you do the sun dance? Otherwise it wont work.
Ok, you all saying there is no solar charge?
no **** sherlock...
But what about all these apps on playstore, they say they can help you solar charge
You're not doing it right. I've been charging my phone with solar power since Nov 2012. Works great.
