Meister-Man
- Apr 20, 2017
Hi guys
We have a 150L solar geyser.
A setup that can be found at lots of complexes.
No inverters, batteries or extra panels.
I'd appreciate your guys' input to the below.
1. What are some of the fundamentals I need to know, to ensure I make the best use of it as possible, by saving on our electricity bill.
2. Can I fit a geyser timer without needing an electrician needed to sign it off? I've heard a story of a person's house being on fire and apparently they had a geyser timer installed at the DB board that wasn't installed by a qualified electrician, so claim was rejected. I don't know if this is true.
3. If manually or by timer, what times should I put the geyser on eskom power at the DB board?
My general idea is, when sun is down geyser on, sun is shining geyser off?
4. What do I do on non sunny days or over the colder months?
5. If hot water is emptied at midday and it's a hot day, geyser switched on at DB board, how does the system decide between using eskom or the sun to heat up the water?
6. What temp to set geyser to?
I know 55 degrees is usually ok, but if I'm getting the sun to do it for me (or most at least), why not let the sun heat all the way up 70?
7. How best to structure our lifestyle and timing of showers, washing dishes etc to maximize on the solar? Again, my general idea is do as much as possible while the sun is shining.
MM
MM
