Are you talking of something home made or commercial?Is a solar heated Jacuzzi a better option?
My biggest concern would be the water getting too damn hot. My solar geyser can get the water up to 80 degrees on a decent sunny day.
Given that the element is not exactly small no it won't be cheaper... my jacuzzi element is a 3kw element I think.. so you would need to be able to provide it sufficient power to run a 1kw motor and 3kw element...Sorry I should have said solar panels. Is it cheaper - still have to have the pump running? Will it take longer to heat up?
