leon.davibe
- Feb 3, 2009
With the array size i would do 1I would go with a 2kw element, that is what I did, a 1kw will use the same amount of power just takes 3 times longer to heat the water. What I did was look on a sunny day when we have excess power and then set the geyser to run for 45 min in the morning excess and 30 min in the afternoon excess. Also with regards to the geyser, my 2c worth rather install more panels than go solar geyser. Once your geyser is hot then that is it, with solar panels you can use that extra power once the geyser has been heated with the system.
(If single bath session at night)
So lets say he 2kw element gets 3kwp
Geyser uses 2kw that leaves 1kw
If battery reserve is in play
So any use that exceeds 1kw like making coffee will come from eskom even if full sun
Luckily the battery will be full most of the time , so maybe doing smaller element isn't needed, but the battery would have to micro cycle to get the most out of it
Now lets say semi cloudy and production dips to 1kw
Now you are using eskom to heat geyser if the battery is worked down to reserve
So you would have to change the reserve % based on weather /shedding
Small battery bank means lots of micromanaging inverter to get most savings
